- 22 Dec 2005
Thermaltake A1899 Chipset Cooler (009159)
I found a few reviews on an american site: I think this is what'll I'll go for (reviews were for A8N SLI mobo's)
Pros: -Good fan overall, i gave it a high rating but im mostly gonna concentrate on the cons. -easy installating -Can mount on any MB preatty much, i mounted it on an ASUs A8N-E mb. -thermal grease included -South Bridge heatsync also included Cons: -Need to use the fan speed controller included in the package in order to get Low-Med-High settings. I tried hooking the fan directly to the MB adaptor and the fan goes to its 9000RPM status -Loud on anything but 5kRPMS right now my nforce4 chipset is at 27 celsius while running world of warcraft and a whole bunch of other apps in the background.
good fan had some troubles with the posts other than that im happy
Nicely done, lowered my temp by 2 degrees and stays stable. Recommended for high-end mobos with intel HT technology
good product-easy install-would recommend it to anyone
Installed it into an Asus A8N-SLI Deluxe mobo based system. According to online forums, the chipset fan on these boards is problematic. Mine started ''performing'' at 700 RPM's or so and then I found this... Installing this fan because of the push pin set up was a pain in the neck. Not because of ThermalTake... because of the mobo setup. Mobo had to be removed, pins clips and then this installed. Fairly painless install. The perfomance is awesome! It IS a little loud at full steam but it's better than frying your chipset. If you overclock, get it. You need it. You won't be sorry unless you don't have it...!
Great mounting. Little loud at full steam, but it sounds pretty cool. Like a jet. My computer loads video games a lot faster now.
