http://valid.canardpc.com/show_oc.php?id=1844405
Left it at 4.5.
Had the multiplayer at 4.8 np's, idle was about 36, but running intelburn got it to 90 quite fast.
At 4.5 intel burn hits 70-75 ith 27-29 idle.
So, I'll stick with a slower clock and lower speeds. Overall pretty happy with the cooler, it's reasonably quiet, and makes a marked difference in cooling from stock.
On stock clocks was getting pretty high 70-80 temps on standard with intel burn. 98 on max.
Now only 70.
*edit*
Want to ask if its normal for CPU-z to always show the clock as being 4.5
I assumed speedstep would underclock when the cpu wasn't in use. Not that it matters too much, but I think I'd prefare it to step down when not needed.
Left it at 4.5.
Now only 70.
*edit*
