Im after a new one since the fan on my arctic freezer 7 pro rev 2 went kapputt, problem is ive only got 165mm space from motherboard to side of pc. Am i better off just getting another freezer 7 or is there any other you'd recommend, think i might have to stick to ones with 92mm fans as i dont think theres much space for anything bigger and im not into massive coolers anyways....My pc is under my desk and there isnt room to modify the panel,ive got a coolermaster praetorian 730 case if that helps. I dont overclock but do a lot of gaming...Thanks ..oh nearly forgot my motherboard is a Z77 asrock extreme4 skt 1155
