NEW CORSAIR PROFESSIONAL SERIES™ GOLD AX HIGH PERFORMANCE POWER SUPPLIES - PRE ORDER
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Corsair Professional Series™ Gold AX750 High Performance 750W Power Supply (CMPSU-750AXCN) @ £159.99 inc VAT
The Corsair Professional Series Gold power supply pushes the state of the art for reliable delivery of clean power under imperfect conditions. If you require mission-critical stability or you simply want one of the best power supplies available, the Professional Series Gold is for you. All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow. And, when it's time to replace or upgrade your power supply, it can be removed from your system without interfering with your cabling — the cables stay in place and connect to your new fully-modular Corsair power supply. With 90% efficiency at 50% load, the Corsair Professional Series Gold power supply runs quieter, generates minimal excess heat, and saves you money every month. It's earned the 80 Plus® Gold seal of approval, your guarantee that you're making the right choice for smart, efficient power delivery.
- 750W of sustanable power
- Supports the latest ATX12V v2.31 and EPS 2.92 standards and is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
- An ultra-quiet 120mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- 80 Plus Gold certified to deliver at least 90% efficiency at 50% load
- Active Power Factor Correction (PFC) with PF value of 0.99
- A dedicated single +12V rail offers maximum compatibility with the latest components
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components
- High-quality Japanese capacitors provide uncompromised performance and reliability
- Completely modular cable system allows you to use only the cables you need
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer's chassis
- A seven year warranty and lifetime access to Corsair's legendary technical support and customer service
- Dimensions: 150mm(W) x 86mm(H) x 160mm(L)
- 7 Year Warranty
Only £159.99 inc VAT.
ORDER NOW
Corsair Professional Series™ Gold AX850 High Performance 850W Power Supply (CMPSU-850AXCN) @ £179.99 inc VAT
The Corsair Professional Series Gold power supply pushes the state of the art for reliable delivery of clean power under imperfect conditions. If you require mission-critical stability or you simply want one of the best power supplies available, the Professional Series Gold is for you. All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow. And, when it's time to replace or upgrade your power supply, it can be removed from your system without interfering with your cabling — the cables stay in place and connect to your new fully-modular Corsair power supply. With 90% efficiency at 50% load, the Corsair Professional Series Gold power supply runs quieter, generates minimal excess heat, and saves you money every month. It's earned the 80 Plus® Gold seal of approval, your guarantee that you're making the right choice for smart,efficient power delivery.
- MTBF: 100,000 hours
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick
Only £179.99 inc VAT.
ORDER NOW
Corsair Professional Series™ Gold AX1200 High Performance 1200W Power Supply (CMPSU-1200AX) @ £264.99 inc VAT
The Corsair Professional Series Gold power supply pushes the state of the art for reliable delivery of clean power under imperfect conditions. If you require mission-critical stability or you simply want one of the best power supplies available, the Professional Series Gold is for you. All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow. And, when it’s time to replace or upgrade your power supply, it can be removed from your system without interfering with your cabling — the cables stay in place and connect to your new fully-modular Corsair power supply. With 90% efficiency at 50% load, the Corsair Professional Series Gold power supply runs quieter, generates minimal excess heat, and saves you money every month. It’s earned the 80 Plus® Gold seal of approval, your guarantee that you’re making the right choice for smart, efficient power delivery.
- An ultra-quiet 140mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer’s chassis
- A seven year warranty and lifetime access to Corsair’s legendary technical support and customer service
- Dimensions: 150mm(W) x 86mm(H) x 200mm(L)
- Seven Year Warranty
Only £264.99 inc VAT.
ORDER NOW
I guess in the long term, it would save you more money on your electricty bills ;)
But I dont know why, but I hate the way they look, just like plain black boxes.
Quite a price jump from the HX series but you get what you pay for also 90% efficiency is just awesome.
And the 7 year warranty.
Anything else would just be tacky though!
No easy task, Corsair said it incorporated a number of "sophisticated server-level technologies" to reach 80 Plus Gold status, including Zero Voltage Switching and Zero Current Switching tecnology to eliminate switching losses and reduce EMI, as well as individual DC-to-DC voltage regulation for the 3.3V, 5V, and 12V rails. In addition, Corsair claims its secondary-side synchronous rectification and 4-layer PCB design results in low levels of ripple and noise.
All three power supplies come with a single 20/24-pin ATX connector, two 8-pin CPU connectors, and a single floppy connector. The AX750 adds two 6+2-pin PCI-E, 12 SATA, and eight 4-pin connectors, while the AX850 ups the ante to four 6+2 pin connectors. The flagship AX1200 features six 6+2-pin, 16 SATA, and 12 4-pin connectors.
Each PSU also boasts a single +12V rail with 62A (744W), 70A (840W), and 100.4A (1204.8W) available on the AX750, AX850, and AX1200, respectively.
100 AMPS ON A SINGLE RAIL?!
Tasty.
i pretty much decided from day one my new rig(before christmas 2010) would have the corsair hx 850 as it has according to hard ocp 88% efficiency now this comes out whats best?
for £20 more what do u get with the gold 850w? i dont think id ever use more than 1 gfx card as i despise all kinds of stutter and well i find it doubtful it would be good enough for my picky needs smoothness wise, so gtx 480 and a 6 core gulftown at 4.20GHZ what kind of amps on a single rail would that pull?
and what did the hx 850 what have on its single rail?
