You did indeed, you also suggested leaving DDR_1 and DDR_2 free. Which it turns out is not possible under any scenario, unfortunately![]()
It's worth a try as a way of using all 4 sticks of the OP's existing RAM.
I did caveat my posts stating that it might not work.
Have you tried running the 4 sticks in the slots furthest away from the processor leaving the 2 closest slots empty?
If it works you'd have more room for the larger CPU coolers.
I was just suggesting you try it the way I said.
If it doesn't work you've lost nothing.
If it does work then you don't need to spend any more money on RAM and you've made more room for the CPU cooler.
Edit
If the OP is feeling bold then they can, at their own risk, try this:
Corsair Vengeance Tall Heatsink Removed!!!
