new cpu cooler
28 Jul 2015
ive just installed a bequiet pure cooler on my i5 3570k, its only been on for a few hours however the idle temps seem a little high, 33 - 38 degrees??
thought it might be cooler than this. I know the weather is rather warm today (22degrees) but was expecting more.
does it take a few days for things to settle down?
Run at 100% with Prime and check the temps.
Are you overclocked at all, also how are your fans connected ?
Well some people will say you should remove the paste and apply your own. Personally pre applied thermal has worked really well for me.
No, it should settle fairly quickly. Honestly those idle temps are fine for an air cooler and it won't take off years of your CPU.
67C seems pretty good for an air cooler on a 3570k. You should only be worried if temps hit 90C, temps shouldn't really go above 80C if you want your chip to last. :p
Don't worry, 67C is perfectly safe.
