- 9 Nov 2014
Hi all,
I recently purchased and installed an EK P360 Kit but have run into a few things I'm concerned about.
Firstly there is a strange black material on the water block that wasn't there when I first installed it. Is this normal or something to be worried about?
Secondly, there are quite a few very small bubbles in the block and reservoir that don't seem to disappear despite my shaking and moving my case around. Again, is this OK?
Lastly, I'm disappointed with the actual performance of the loop. I original had a bequiet! Shadow Rock LP cooler and it kept the CPU at around 70C at full load. The new EK Kit I have installed keeps the CPU between 60-70C at full load. I though it would cool much better than this.
Am I simply expecting too much or could there be a fault? I've checked all the fittings etc and can't find any leaks or blockages.
This is my first foray into water cooling so any help is greatly appreciated.
EDIT: to confirm the CPU is running at stock speeds and stock voltage.
