- 2 May 2012
Hi,
Looking for some help. I bought my last PC from OCUK many moons ago (2012) and started on this very helpful forum and eventually bought it over the phone and had it built.
I'm looking to upgrade and get something decent to play PC games as mine is obviously slow now and technology has advanced massively. Saying this it still amazing works apart from having to replace a graphics card ( think its a Geforce 1050). It's obvious when your work laptop is faster than your old gaming pc.
Depending on the benefit i'd roughly want to spend around £1,300 give or take. I like the look at some of the below but I have no idea if they are great or if there is better for roughly the same cost? I would imagine I need to add Windows 11 to the build and more fans, not sure if I am missing anything else. I have Windows on this computer (the old one) but assuming it won't carry over? Part reason for the upgrade is Windows 11 isn't supported on my current one.
TeamGroup Vulcan 32GB (2X16GB) DDR5 PC5-44800C36 5600MHz Dual Channel Kit - Black (FLBD532G5600HC36BDC01)
Lian Li Lancool 205 Midi-Tower Case - Black Window
Team Group MP33 PRO 1TB SSD M.2 2280 NVME PCI-E Gen3 Solid State Drive
Aerocool Integrator 600W 80 Plus Bronze Power Supply £41.99
Thanks in advance
SAPPHIRE PULSE AMD Radeon™ RX 7800 XT Gaming Graphics Card with 16GB GDDR6, AMD RDNA™ 3 architecture £518.99 £469.99 (incl. VAT)
Intel Core Ultra 5 245KF (Arrow Lake) Socket LGA 1851 Processor - Retail £278.99
Asrock B860M-X WIFI (LGA 1851) DDR5 Micro-ATX Motherboard £127.99
TeamGroup Vulcan 32GB (2X16GB) DDR5 PC5-44800C36 5600MHz Dual Channel Kit - Black (FLBD532G5600HC36BDC01) £89.99 £79.99
Lian Li Lancool 205 Midi-Tower Case - Black Window £64.99 £54.95
Team Group MP33 PRO 1TB SSD M.2 2280 NVME PCI-E Gen3 Solid State Drive £49.99 £43.99
Asus Ultra Slim 9.5mm Internal DVDRW (SDRW-08U1MT) £19.99
https://www.overclockers.co.uk/sapp...s-graphics-car-gra-spr-00764.html#see-reviews
Thanks in advanceSAVE 25%
£240
(incl. VAT)
£180
(incl. VAT)
£110
(incl. VAT)
