I am looking to add a waterblock into my existing loop, the addition being a waterblock for my Gigabyte 1080 D5X graphics card.
I currently have a Raystorm V3, which I believe is a Copper based block. I am also using Mayhems Pastel fluid. Now, my understanding is that you shouldn't mix metals in your loop, so based upon this, I would need a Copper based GFX block.
However, all the blocks I can find that will fit the above GFX card appear to be nickel plated, so if my understanding is correct, are not suitable.
So, ultimate questions are..
Many thanks.
- With that fluid, do I have to keep metals in the loop the same?
- If yes to the above, what GFX block can I use in my loop?
Many thanks.
