So I used to own a 5870 which i used to power my desktop monitor via dvi-hdmi cable and HDTV via a HdMI-HDMI cable.
Everything worked fine.
I've since upgraded to a 6970.
Now my monitor works fine using the dvi-hdmi cable but for some reason the HDTV just refuses to get picked up using the HDMI-HDMI cable. So I thouhgt dodgy HdMI port as the cable worked on the 5870.
But no, I tested the monitor using a separate hdmi-hdmi cable and worked fine.
So for some reason my normal HDMI-HDMI cable which worked fine on a 5870 doesn't work on a 6970 even though the HDMI slot does work.
Can someone shed some light please????
