new GPU installed, is my GPU and CPU running correctly ?
Underboss
20 Oct 2002
Oxfordshire / Bucks
Does this look right (idle)
Slightly weird readings on the graphics card there implying it's at 0mV core voltage and 6MHz clock speed but it's probably fine.
Looks like graphics card temperatures are a little high if 53°C is lowest/idle temp.
Not much information to be gained from that picture, is the PC behaving ok? Have you tried using the PC?
Just wanted to know if CPU and GPU settings were right
I didn't realist the 5700 xt drops voltages and fan speeds to zero or near lol
I'm setting it so it doesn't do that to test idle, I'll have to update again tonight
Cheers
i use afterburner and in the settings menu there is an unlock voltage monitoring option that allows afterburner to report voltage.
