Hi, im a OcUK customer looking for some help if possible. I'm only a novice with computers. Around 4 years ago i bought a mid range system, i5 3570k, radeon 7850 card. The other day i believe my graphics card died, all the screen was fuzzy a lot and windows would crash seconds after loading up, some flashing like an old rewinded VHS etc. And light blue screens of death and grey screens of death. Meanwhile using the onboard gfx was fine. Then i ended up messing my windows up somehow trying to fix it, at that point i was hoping it wasn't my card. So i took it to a pc repair shop, and it came bk with clean windows install and even gfx card seemed fine. Played a game or 2, then the fuzzyness problem came bk, even the motherboard load screen was fuzzy. Again it was fine on onboard.
Next I went to overclockers this saturday just gone and bought a new card, MSI GTX 960. Put it in and it works, played a game and stuff. I also bought 2 case fans, which i plugged in and also work. But i noticed the motherboard screen stays on for so long, maybe 1-2min, the screen where it says press such and such to enter BIOS. During this period i can't enter BIOS or anything on that screen. Then windows loads as normal. Today I moved my pc, took cords from the back to move it. When I came to plug those back in and turn pc on, the pc would try to power up but fail after half a second. It would continue to do this every couple secs, maybe 6 times, then it would boot up but after the long motherboard screen, it would give a black screen and not load windows. I have a video here of that bit:
This happened with both GFX card and onboard. At this point i also noticed something odd, 2 leads which looked melted or something:
https://postimg.org/image/f958alyep/
so i pecked this white stuff off, leads said power led +/- and plugged them in (wrongly) and tried boot then realised and put them in correct and tried boot, still no difference, though it did boot once straight away without the half second attempts, but still leading to the same black screen. At this point (maybe 7 hours ago) i gave up and was looking at salvaging and maybe getting a new pc. Then i just tried again before I go to sleep, plugged the 2 little leads in to the matching + and -, tried boot with onboard and it worked....so then i just tried with GFX card again and now pc is back on again, though with gfx card still having a long time on BIOS screen and seemingly unable to enter it. Now i am afraid to move my pc even an inch, can anybody help me to:
- Find out why the long loading BIOS screen with new card, and why I'm unable to enter it also.
- If those 2 little pins are significant, i did read they just powered the front panel.
- Why i had these problems today and how I can prevent it? I'm used to moving the pc around a lot and to clean it now im afraid to even nudge it.
Thank you for any help
thank you very much for the help.
