Hey all, wondering if you could give me some much needed help.
Got myself a new harddrive today, need to install a fresh copy of windows on it and start from scratch.
The harddrive is picked up in the bios, I can select it in boot priority etc. so at least I know its there.
Anyway, I select my dvd drive in the boot priority menu to install windows from CD, get past the RAID driver install and after hitting Enter to start a windows installation, I get told that there is no harddrive installed on the computer, i.e nothing is there or nothing is recognised.
I have tried this WITHOUT the raid drivers, same thing. And obviously WITH the raid drivers aswell, still get the same message.
Only problem I can think of is that the RAID drivers I have on floppy disk are from about 3-4 years ago, I have just had my bios updated on my harddrive, could it be compatibility issues? Should I try and find new raid drivers for my harddrive/motherboard?
For the record, my motherboard is an ASUS K8V-SE Deluxe. Any help at this point is intensely appreciated. Been without my desktop for weeks and when I finally think its sorted,, It isnt.. Please advise!!!
Many thanks,
Evol
Many thanks,
Evol
