New(ish) build problem...
13 Jun 2009
Hi guys
I bought the parts needed to build a complete new system from here a few weeks ago, everything was fine, the build went well and the system had been running fine untill this morning.
When i turn on the computer everything powers up ,well the fans do anyway, but the graphics card lights (2 little red diodes on the back of the card) continually blink and nothing appears on my screen, The lights blink in a series of 4 flashes (if that info helps?) that continues untill i power off and neither of the dvd drives will open.
I'm thinking it could be a psu problem, but i dont see how this has happened, the rig has been working fine for nearly a month now, with no major changes to devices or drivers etc.
I've tried re-seating the gfx card, using a different 6-pin PCI-E cable from the psu, disconnecting all devices and trying to boot with just the gfx card, and ram, but still get nothing.
There have been no changes to any of the drivers, devices attached, system configiration or anything else recently, the computer was fine last night when i shutdown as normal, but this morning its having problems
Any help would be much appreciated.
Thanks
Support Details:
Motherboard: Gigabyte GA-MA790XT-UD4P
Motherboard Driver: As supplied from Overclockers
Motherboard Chipset: Unsure
Motherboard BIOS: Unsure
CPU: AMD Phenom X3 tri core 720 2.80GHz @ 3.50Ghz (oc'd by overclockers btw)
Memory: Corsair 4GB DDR3 XMS3 PC2-1600C9DHX TwinX (2x2GB)
Memory Latency: Unsure
PSU: Corsair TX 750W
Fans: 2x 120mm case fans + 3 60mm fans
HDD: 1 western Digital Caviar black 1TB + 1 western digital caviar blue 250GB both SATA
Drives: 2x DVD ReWriters both IDE type
Graphics: Asus ATI Radeon HD 4850 512MB
Graphics Driver: As supplied (something like catalyst 8.17 i think)
Sound Card: On-Board
Sound Driver: Realtek HD
Operating system: Windows XP SP3
Changes prior to problem: None
(All the parts listed came from overclockers)
Do you have another PSU you could try? Even just a crappy old one to see if it boots. Take out the graphics card and leave just 1 stick of memory in and see if it boots. You didn't have lightning last night did you?
I do have a crappy old psu, but, it doesnt have the right connector for the psu to the mobo, tryin to find a mate with a spare now though.
I've already tried using just single sticks of ram but no joy there, will try again when/if i find another psu.
Nope, no lightning last night.
