Permabanned
- 4 Jul 2011
AMD Phenom II quad core 955 Black edition 3.2 Ghz = 80 Quid
Extra Value 4GB DDR3 1333MHz Memory Module + £28 ******
http://www.******.com/product/232760
Casecom Silver 500W PSU - With 12cm Red LED Fan, 20+4pin 1x SATA, 1x PCI-E
http://www.******.com/product/129423 =£17
Asus M4N68T-M LE V2 Socket AM3 DDR3 Geforce 7025 VGA Out 8 Channel Audio mATX Motherboard
http://www.******.com/product/246637 £34.37
I know the psu's on the cheap side, but its the only one in my budget with a gaming card power port.
Thanks!!
p.s I know the psu's a bit naff, but was thinking of this
http://www.******.com/product/255695
But I want to keep the costs as low as possible. TOTAL =£160 with this psu.
I have already managed to get a floppy style 6 in 1 card reader, a 160gb 5200rpm which will have to do for now and a standard atx case. I also will be buying a <£40 graphics card soon if budget allows.
So what do you think, a gaming machine for £150... or not.
So if I do get a graphics card, £200, is this too good to be true, I want to run all the latest games at very high fps..
Many Thanks.
Jay
The Stars theyve put in are just the '******' website, just replace that in the link!
Thanks!!
Many Thanks.
Jay
