New MB Graphics and poss mem..advice?
How about a GA-P35-S3 or Abit IP35-E these are under £70
Plus 320mb 8800GTS which are about £180
and 2Gb Corsair XMS6400C5 Ram at about £60
Total about £320inc. then sell the X1950Pro AGP for £85-90 and the mobo and 3400 for £35.
Sorted??? ;)
How about:
Gigabyte GA_965P_DS3P (Socket 775) £100
HIS ATI Radeon X1950 Pro ICEQ 3 V2 TURBO SILENT Heatpipe 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (H195PRQT512DD-R) £135.11
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit (BL2KIT12864AA663) £64.61
bloodline76 said:
How about:
IMHO - if your gonna run the same level of gfx ie X1950 pro then use the one you have in a ArSock DualVSTA as your suggestion does not give you a worthwhile increase in performance for the cost.
If you want an intel chipset mobo then go for the latest P35 chipset.
Be aware that the Ballistix Ram you suggest has had lot of failures during the past few months.
Hope this helps
Hope this helps
The reason I was going to go for that is ideally I would like to move to pci-e as i am agp but need the cheapest step up.
