- 29 Aug 2010
- Bedfordshire
Hi,
i have just ordered my kit, i did want to ask a few questions but i had to wait patiently for my forum account to be activated for 4 days, turns out i couldnt wait and the kit is on its way. i have been reading hundreds of threads and post on this forum and found some very helpful information which i have used to generate my list and created a wish list for future improvements.
i am an electronics design engineer and my use will mainly be based around PCB design, VHDL / FPGA design, microcontroller software design, CAD, and solidworks. But on top of that i will be using for media and might try a little PC gaming if i have the time (my PS3 gets very dusty sometimes).
here is what i have ordered -
I7 950
ASUS P6X58D-E
PALIT GTX460 1GB sonic platinum
Corsair Dominator 6GB CMP6GX3M3A1600C8
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB
Corsair 850AX
Corsair 600T
2 X BenQ G2420HD 24
Samsung SATA Blue Ray SH-B083L/RSBP
got that lot for just under £1300 delivered (mainly form other suppliers) which i was fairly happy with.
does the list look ok?
most parts should be here this week, apart from the case of course, it was listed as four week lead time for pre order, after i ordered, they specified a delivery date of 25/10/10!!! i was just going to run the components up on my desk, but thats a long time, so might have to order another case for the time being, i was thinking a fractal Design R2 or R3 if i wait just over a week.
i want to get some SSD's in the system, but the general feeling i get is that it is probably worth waiting a little longer to get better deals and performance.
i want to start trying a little overclocking, nothing extreme, just like to tinker, so i need to sort out an aftermartket CPU cooler, i like the looks of the H70/H50 coollers, and they would fit right in place in the 600T case, but after reading some reviews i am not sure.
what heatsinks could i use in my setup (bearing in mind the dominator RAM)?
theres nothing exciting in my build, but ill put some pictures up as i go anyway, and i am sure i will be back for lots of advice and help!
cheers
I7 950
ASUS P6X58D-E
Corsair 850AX
Corsair 600T
2 X BenQ G2420HD 24
cheers
cooler wise I have the Thermalright Venomous x which gives better performance that the H50 (and I think the H70) and looks bloody good so I recommend it
