** NEW OcUK Pre-Watercooled Case Range **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Just in time for the weekend, OcUK are proud to announce the availability of a full case range with pre-installed watercooling kits.
These kits are assembled in house and ready for you to build your dream PC inside.
As with all OcUK watercooling products, the sheer variety of kit on offer means that we are always open to suggestion. If you require a certain case/coolant/tubing layout. Then please call our sales team who will be happy to amend or customise your pre-watercooled case to your requirements [dependant on compatibility].
OcUK V6 Watercooled Case - BitFenix Shinobi **2011 Compatible** @ £200.00 inc VAT
Assembled by Expert OcUK Technical Staff, the V6 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money!
The OcUK Watercooled Case range comes pre-assembled for your convenience. All of the difficulty of watercooling has been removed and allows you to enjoy the best performance without the hassle.
All of our pre-watercooled cases are built to order and come pre filled ready for you to build your dream system.
The system is shipped with Clear Mayhems Ultra Pure Fluid. If you prefer us to use a coloured fluid or specialist liquid, you can choose from a wide range
All you need to do is build your PC and install the waterblock which is just as easy to do as mounting any CPU cooler.
All leak testing and filling is carried out by our technical staff which means that the watercooling system is ready to use by you when it arrives. All that is required is for you to plug the pump and fans into your power supply.
PLEASE CHOOSE THE CORRECT MOUNTING BRACKET FOR YOUR CPU
BitFenix Shinobi Gaming Windowed Case - Black
- Dimensions: 205 x 460 x 490mm
- Motherboard Sizes: Mini-ITX, mATX, ATX
- 5.25" Drive Bays x 3
- 3.5" Drive Bays x 8
- 2.5" Drive Bays x 2
- Front Cooling: 2 x 120mm Fans (optional) 1 x 120mm Fan (included)
- Rear Cooling: 1 x 120mm Fan (included) or 1 x 92mm Fan (optional)
- Top Cooling: 2 x 140mm Fans (optional) or 2 x 120mm Fans (optional)
- Bottom Cooling: 1 x 120mm Fan (optional)
- Expansions Slots: 7
- I/O Ports: 4 x USB2.0 & 1 x Audio
"EK-KIT H3O - Supreme LT 120" water cooling kit includes following items:
- EK-Supreme LT - UNI (universal CPU block based on EK-Supreme LT)
- EK-Backplate CPU Universal
- EK-CoolStream RAD XT (120)
- Yate Loon D12SH (2200rpm) or Yate Loon D12SM (1650rpm)
- EK-DCP 2.2 Pump
- EK-Reservoir Combo DCP 2.2
- EK-DCP PUMP mounting plate KIT
- TUBE Masterkleer 12,7/9,5 CLEAR (2 meters)
- EK-PSC Fitting 10mm - G1/4 Nickel (6 pcs)
- EK-Ekoolant UV Blue (concentrate 100ml)
- TIM Arctic Cooling MX-2 (EKWB 2g)
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in complteing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Only £200.00 inc VAT.
ORDER NOW
OcUK V6 Watercooled Case - Zalman Z9 **2011 Compatible** @ £184.99 inc VAT
Zalman Z9 Plus Tower Case with Fan Controller - Black
- Motherboard tray cut out for easy CPU backplate removal
- Dimensions: 207 x 464 x 504mm (W x H x D)
- 3 x 5.25" Drive Bays
- 6 x 3.5" Drive Bays
- 1 x 2.5" Drive Bay
- Expansion Slots: 7
- Space for 290mm Graphics Cards
- Front I/O Ports: USB2.0 x 4 / 2 x Audio / Fan Controller / Temperature display
- Front Cooling: 120mm /140mm fan x 1 (120mm Blue LED fan x 1 standard)
- Top Cooling: 120mm /140mm fan x 2 (120mm Blue LED fan x 1 standard)
- Bottom Cooling: 120mm /140mm fan x 1 (optional)
- Rear Cooling: 120mm fan x 1 (included)
- Side Cooling: 120mm fan x 2 (120mm Blue LED fan x 1 included)
- EK-DCP 2.2 Pump
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Only £184.99 inc VAT.
ORDER NOW
V8 Double Radiator Cases
OcUK V8 Watercooled Case - Corsair 650D **2011 Compatible** @ £300.00 inc VAT
Corsair Obsidian 650D Gaming Midi Tower - Black
- Motherboard Support: ATX / mATX
- Expansion Slots: 8
- Drive Bays: 5.25" x 4 & 3.5"/2.5" x 6
- Cooling: 2 x 200mm Fans and 1 x 120mm Fans
- Front I/O Ports: USB2.0 x 4 / FireWire x 1 / Audio x 2 / 4-Channel Fan Controller
- Dual 200mm fans provide outstanding cooling for even the hottest components
- Easily accessible dust filters make maintenance simple and hassle-free
- Quick-release side panels make it easier than ever to upgrade your hardware
- Integrated fan controller lets you quickly adjust cooling performance and noise levels
- Four tool-free optical drive bays and up to six SSD-ready hard drive trays provide plenty of expansion
- CPU backplate cutout makes it easy to upgrade your CPU cooler
- Brilliant cable routing system provides a way to keep your system neat and tidy
- Adjustable drive cages can be removed and relocated to accommodate large video cards
- Room for long power supplies gives you peace of mind for future upgrades
- Dimensions: 546mm (L) x 229mm (W) x 521mm (H)
EK-KIT H3O - Supreme LT 240 water cooling kit includes following items:
- EK-CoolStream RAD XT (240)
- EK-DCP 2.2 Pump
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Only £300.00 inc VAT.
ORDER NOW
OcUK V8 Watercooled Case - Cooler Master CM-690 Lite Dominator @ £230.00 inc VAT
The system is shipped with Clear Mayhems Ultra Pure Fluid. If you prefer us to use a coloured fluid, please call our sales team to enquire about coloured coolant.
Cooler Master CM-690 II Lite Dominator Case - Black
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1x 120 mm (17 dBA)
- Rear Cooling: 1x 120 mm (17 dBA)
- Top Cooling: 2 x 140 / 120 mm (optional)
- Bottom Cooling: 2 x 120 mm (optional)
- HDD Cage cooling: 1x 120 mm (optional)
- EK-DCP 2.2 Pump
Only £230.00 inc VAT.
ORDER NOW
V12 Triple Radiator Cases
OcUK V12 Watercooled Case - Corsair 800D @ £400.00 inc VAT
Corsair Obsidian 800D (6GB/s) Full Tower Case - Black
- Four easily accessed hot-swap drive bays
- Removable CPU backplate panel for easy heatsink installation
- Isolated cooling zones prevent heat buildup
- Unique cable routing holes guarantee a clean and clutter-free installation
- Three fans included, with the ability to add four more 120mm fans
- Tool-free optical drive installation makes building a system faster than ever
- Two year warranty with Corsair’s world-class customer service and technical support
- Dimension: 609mm X 609mm X 229 mm
- 5 x 5.25" Drive Bays
- 4 x 3.5" SATA Hot Swappable Bays
- 2 x 3.5" Internal Bays
- Cooling: 3 x 140mm fans (included)
- Cooling: 4 x 120mm fans (optional)
- Front I/O: 4x USB 2.0, 1x FireWire, 2x Audio
EK-KIT H3O - Supreme LT 360 water cooling kit includes following items:
- EK-CoolStream RAD XT (360)
- EK-DCP 2.2 Pump
Only £400.00 inc VAT.
ORDER NOW
OcUK V12 Watercooled Case - Coolermaster HAF X @ £309.98 inc VAT
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, GFX cards and is even USB3.0 compatible. With specialised support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this is as close as it gets to a system builder's 'dream case'.
- Dimensions: 230 x 550 x 590mm ( W x H x D)
- Motherboard Compability: Micro- ATX, ATX and E-ATX
- 6 x 5.25" Drive Bays
- 5 x 3.5" Drive Bays
- I/O Panel: USB3.0 x 2, USB2.0, Audio x 2, e-SATA x 1, FireWire x1
- Cooling (Front): 230 x 30 mm red LED fan x1
- Cooling (Top): 200 x 30mm fans x 2 (1 included)
- Cooling (Side): 200 x 30mm fan x 1
- Cooling (Rear): 140 x 25mm fan x 1
- VGA Fan Duct: 120 x 25mm fan x 1 (not included)
- VGA Holder: 80 x 15mm fan x 1 (not included)
- PCI Slots: 9
- Bottom mounted PSU
- EK-DCP 2.2 Pump
Only £309.98 inc VAT.
ORDER NOW
And Now, the all new Daddy of watercooling cases.
OcUK V12 ULTIMATE Watercooled Case - Xigmatek Elysium **2011 Compatible** @ £444.98 inc VAT
The Ultimate Watercooled Case has arrived. Achieving near silent operation and using only the finest watercooling components available, this case has everything that you require to build the ultimate system.
Assembled by Expert OcUK Technical Staff, the V12 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money!
This special addition uses premium, uncompromised watercooling components to ensure Ultimate Performance.
All of our pre-watercooled cases are built to order and ship pre filled ready for you to build your dream system.
Component List:
1X Xigmatek Elysium Full Tower Windowed Case - Black
One of the most versatile Watercooling Cases on the market, with the design and reputation that few rivals can beat.
1X Hardware Labs Black ICE SR-1 360 Radiator
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.
1X EK Supreme HF CPU Waterblock - Copper Plexi
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!
1X Alphacool Laing D5 Vario Pump 655
The Best watercooling pump on the market. Needs little introduction.
1X Alphacool HF D5 TOP - Black Acetal G1/4
The ultimate top for your pump offers even better performance as well as more mounting and connective possibilities
1X XSPC Single 5.25” Bay Reservoir
Single bay reservoir for installation into the 5.25" optical drive bay.
6X EK PSC Compression Fitting 7/16 [16/11mm] - G1/4 - Nickel
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
1X Mayhems Ultra Pure H20 Watercooling Fluid
The purest water available - ensuring the best temperatures.
1X XSPC 7/16" ID [16/11mm] High Flex Hose - Clear
High quality watercooling tubing with a superb bend radius
3X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Only £444.98 inc VAT.
ORDER NOW
how would this work - i build my system inside AFTER the watercooling loop is installed? wouldnt that be very awkward?
I assume its pre built, you just build around it. Cant be too hard, just simple case screwing the cpu block down ontop of you mobo?
put the mounting hardware on your board and install your board.
then with the board installed, mount the cpu block. then you are good to go.
the kits used come with full mounting instructions for the end user :)
mounting a waterblock is easier than mounting most air coolers!
its 4 screws.
I have built probably thousands of computers, and would sooner mount a cpu block than any cooler. once the mounting hardware is on the board, it is a walk in the park!
this is custom water with massive convenience!
not at all considering the time they take to set up and test.
The kit is put together by an OcUK system builder, it is not a simple warehouse pick.
Not to mention the 8 hour leak test that the customer doesn't have to worry about...
faulty pump? not a problem to the customer
split o-ring on a fitting? not a problem to the customer
leaky block/rad?not a problem to the customer
everything is taken care of.
they are fitted with kits that provide excellent value for money that I have tested myself. they wouldn't be on our website or have an EK logo on the box if they weren't up to scratch.
I would hazard a guess that your opinion is based on what you have read online somewhere and would not be based on personal usage?
you seem to have major problems with our watercooling range recently GM
if you would like to contact me directly, I would love to hear your thoughts on how it can be improved.
One question if the water cooling loop is pre built, how hard would it be to fit in a GPU block as well as a CPU?
How much DIY would that involve?
you would maybe be best doing it yourself then.
these cases come with the watercooling prefitted, filled and leak tested.
putting a gpu in the loop is certainly possible but you would have to drain the loop and undo all of the work.
you would be better off buying a case and an EK Watercooling Kit then fitting it yourself with the vga block of your choice.
you would need to purchase two additional fittings for the block
if you want fittings to match the ones in the kit so it looks uniform, we stock those too :)
HERE
Not at all!
I'm very pleased to see you stocking Black Ice radiators as well as a hopefully expanding range of XSPC products (not saying XSPC are perfect but it's nice to a choice) as well as things like Gentle Typhoon fans which might not be technically watercooling but as stated in that post are a favourite amongst watercoolers.
I really hope your watercooling range expands as it would save me having to buy parts from all over the place.
My comment about "decent" HF kits was badly worded I'll admit, I should have said "better" HF kits.
I'll also admit that I do get a bit wound up with regards to the kits (and watercooled cases apparently) as just about every comment is along the lines of "This is a wonderful new idea. I don't know why nobody has done anything like this before!" when both concepts have been around for years and while they may be getting better I think it's unfair to say that any watercooling kits other than these EK ones have been rubbish. It's not so much the product as the "noise" being made about them. Maybe I'm just annoyed that they came out after I built my custom watercooling loop (especially as I get such disappointing results from it).
On a side note, this thought/question just occurred to me...
The CoolerMaster 690 II case (which I own and I'm not a fan of) can fit a radiator in the top and bottom. I've got an XSPC RS240 rad in the top of mine and there's not a massive amount of clearance between that and the top of the motherboard. Now the EK Coolstream XT rad that I believe is in this kit is 12mm deeper than the XSPC radiator, so I was wondering if this would fit in the top? If it does I imagine it's a tight fit and wouldn't make installing the motherboard all that easy (especially considering this concept is presumably for someone without a lot of experience putting a PC together).
The other option is obviously to install the Radiator in the bottom where the extra depth wouldn't be so much of an issue. But if this is what is being done then it might be worth mentioning that the customer would lose the use of all but 2 3½" drive bays. Also, partly influenced by which end the connector on the radiator are located it could dictate the maximum length of the PSU that a customer could fit in the case.
I mostly ask because if the EK rad will fit in the top of the case then I might be tempted to do that with mine.
good to hear your thoughts.
XSPC are a good brand and something we are trying to support as best we can.
once their products have more steam behind them then we will stock a wider range :)
the 240 rad in the dominator?
it fits. you need to put the fans on the top side under the grill with the ports towards the front of the case.
i had one out today and did it.
whilst it IS tight, it is by no means impossible to work with. the standoffs are preinstalled so you just slot the board in place.
there is enough clearance for motherboards with really tall mosfet heatsinks too as i test fitted it with an x58 sabertooth to check.
these products were created by myself. you know how thorough I am :)
Great idea! Seen it on FrozenCPU for a while so nice to see you guys doing it over here.
I've thought of water cooling for years and always been scared of it, but now I can pay somebody to do it for me...
This is a fantastic idea guys. It seems custom water has been dieing a slow death, due to better air cooling and cooler running components. Hopefully this will encourage more people to go with h20, and junk their bloody h50's ext.
