The latest addition to the range
OcUK V12 ULTIMATE Watercooled Case - Cooler Master ATCS 840 @ £449.99 inc VAT
The Ultimate Watercooled Case has arrived. Using only the finest watercooling components available, this case has everything that you require to build the ultimate system.
Assembled by Expert OcUK Technical Staff, the V6 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money!
The OcUK Watercooled Case range comes pre-assembled for your convenience. All of the difficulty of watercooling has been removed and allows you to enjoy the best performance without the hassle.
All of our pre-watercooled cases are built to order and ship pre filled ready for you to build your dream system.
The system is shipped with Clear Mayhems Ultra Pure Fluid. If you prefer us to use a coloured fluid, please call our sales team to enquire about coloured coolant.
All you need to do is build your PC and install the waterblock which is just as easy to do as mounting any CPU cooler.
All leak testing and filling is carried out by our technical staff which means that the watercooling system is ready to use by you when it arrives. All that is required is for you to plug the pump and fans into your power supply.
PLEASE CHOOSE THE CORRECT MOUNTING BRACKET FOR YOUR CPU
Component List:
1X Cooler Master ATCS 840 Classic Case - Black
One of the most versatile Watercooling Cases on the market, with the design and reputation that few rivals can beat.
1X Hardware Labs Black ICE SR-1 360 Radiator
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.
1X EK Supreme HF CPU Waterblock - Copper Plexi
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!
1X EK DCP 4.0 Pump (12v)
A higher performance pump that offers capability alongside a smaller footprint inside the case.
1X EK Reservoir Combo DCP 4.0
A direct input reservoir that provides maximum flow to the pump at all times.
1X EK DCP Mounting Plate Kit
The best solution for mounting the EK DCP 4.0 Pumps
6X EK PSC Compression Fitting 7/16 [16/11mm] - G1/4 - Nickel
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
1X Mayhems Ultra Pure H20 Watercooling Fluid
The purest water available - ensuring the best temperatures.
3X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
Only £449.99 inc VAT.
ORDER NOW
