Hi guys,
Sorted the problem with my HD3850 - turned out to be the CPU so currently running on the single core CPU from my kids PC ( which happens to have a blown Mobo ).
Therefore towards the end of april I am going to be buying new parts. I'm a little out of the loop but was thinking :-
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series AMD Athlon 64 X2 Dual Core 5000+ Black Edition 2.60GHz (Socket AM2)
Asus M2R32-MVP Crossfire (Socket AM2) PCI-Express DDR2 Motherboard
and probably a cooler ( or can I re-use my current 939 cooler? - it's a decent one who's name escapes me right now - big multi heatpipe jobbie with side mounted fan).
I know Intel is the leader in CPU's right now but I have a limited budget and anythings going to be better than my old 3800 X2.
thoughts?
thoughts?
At the moment Intel is just the better choice. Having a E2160 myself I can say they are great chips and you will love them if you are going to overclock
