- 13 Mar 2009
Hiya, I've been posting on this forum for a month or so researching for my new pc and after numerous helpful people on here giving me advice I finally chose the right specification and it arrived today. But I have two problems so far
1. The pc won't connect to my wireless router which is in the room next door. My cheap dell laptop of two years did this with no problem and showed a maximum signal strength signal in the vista connect to a network window. My new pc only shows a weak two green bars of strength and when I try to connect it says unsuccessful!! Damn
Thoughts: Maybe it's to with the case? It's the HAF192 I think it's called. This brings me onto my second problem
2. The fans on this case seem incredibly loud. Specifically it sounds like it's the fan near the back of the case, I can't believe how loud it is. I'm not joking I can close the bedroom door and walk downstairs and still easily hear it.
Initially I thought it was something inside the case whirring whilst the OS installed but now the desktop is there and it's still on whizzing around at full pelt.
I ordered an Asus Triton (CPU cooler?) with this model maybe it is that? The whole reason I got this case was because I had read numerous reviews where it is quiet.
Overall disappointed so far
Any advice on what to do would be appreciated. I will be ringing the shop up in the morning.
Edit: Just to clarify only the keyboard came from OC, but I don't know where else to go for help - place I bought it from is closed now and i only set my new rig up half an hour ago.
