Hey guys..
I've just put together a new config for a friend. Unfortunately, the power button connector is not working, and the only way I can turn on the pc manually is by shorting the two power pins inside the cabinet. Now that is not a long term solution. In the BIOS APM, I've set it to turn on every time the power is turned on, and to use a PS2 keyboard or mouse to turn on-unfortunately, that doesn't work all the time, and if it fails, then I have to open the cabinet. And we both don't have a PS2 kb or mouse.
What can I do to turn on the new PC without making use of the power button on the cabinet?
Can anyone tell me how to sort the switch out? The internal connector that has the problem? Or ANY advice would be appreciated.
Thanks in advance!!
Thanks in advance!!
