New PC Build Advice
Does your RAM have an XMP profile on it? Check in the BIOS. If it does, enable it and your RAM will be sorted.
Those CPU auto-overclock features tend to add rather more volts than necessary; look for some guides and try doing it manually.
Your temperatures look absolutely fine.
Havent got a clue if its got an xmp profile, i take it it would be pretty obvious to see in the bios menu?
ill go the manual route then if thats best, i had read a similar opinion but wanted clarification.
