New PC Build Help
You dont need thermal paste as heatsinks and these AIO coolers come with it.
I also dont think the H105 is a good choice as it is a thicker rad than most and as the rad sits at the front of the case it may restrict room for long gfx cards.
The difference between those tow screens is a USB hub and a fully adjustable stand on the more expensive one (pivot, titl, height etc)
Hi,
After reading the reviews submitted by the people who already bought them, i'd pick the second one.
With the first one people say you need to buy another cable to make it work properly.
Extra cable = extra cost.
Currently typing this from my new PC : )
Only issue I had was the Nepton was incomplete and looks used??
It's missing the mounting bolts, thermal paste and nuts so will have to send it back
Currently using the stock fan.
Also forgot my steam login fml so no gaming until I can sort that out!
I will get some up later : ) thanks for tip.
OC have sent out a replace cooler which I will get installed over the weekend. Need to pick up some alcohol to get the old thermal paste off.
I was considering switching out the Stock case fans, to something a bit quieter any suggestions?
Also what software do you guys use to control fan speed?
