New PC Build help
12 Sep 2020
Hello , I’m looking to get a new PC and need help with the best specs possible. I already have a NXZT H510 case , kraken m22 cooled and GTX 1660 DDR5 graphics card but need everything else. I will use the pc for some gaming and photoshops/video editing. The budget is £550-650. Please spec me out something if possible. Thank you !
Something like this;
My basket at Overclockers UK:
Total: £605.05 (includes shipping: £11.10)​
You can get the 3600 for about 180 elsewhere so look into that to save a little more. You could always get a Ryzen 5000 in the next 18mths if you wanted to upgrade but a 3600 and 1660 would be a nice PC.
Thanks for your reply , that looks good to me , I was wondering if I should get a motherboard with WiFi built in ? I will be using WiFi as I have no access to ethernet cable , is there any good motherboard that will fit within the budget ? Thanks
