- 31 Jul 2010
- Stoke-on-Trent
Hi guys,
I've recently built a new pc the spec is:
Processor - Intel i7 2600k (overclocked to 4.5)
CPU Cooler - Corsair Hydro H70
Memory - Corsair Vengeance 8GB
Graphics Card - MSI Nvidia GTX 580 (overclocked to 900mhz)
Motherboard - Gigabyte P67A-UD5-B3
Hard Drive 1 - Intel 510 Series "Elmcrest" 120GB SSD
Hard Drive 2 - Western Digital Cavier Blue 1TB
Optical Drive - Samsung SH-B123L/BSBP Blu-Ray
Power Supply - Corsair HX 850W ATX Modular
Case - Coolermaster CM-690 II Advanced Dominator
Keyboard + Mouse - Razer Deathadder + Razer Lycosa
I have it overclocked to 4.5ghz at 2.28v with memory timings of 8 8 8 24 which is whats written on the stick (overclockers shows 9 9 9 24) i ran prime95 with no issue for about 12hrs.
So what basically happens is when it's running the computer is fine, no issues it's spot on.
When i turn it all off and leave it for a couple of hours, when i turn it back on it boots up, screen stays blank and then restarts, it then continues to stay in a boot loop.
I switch it off, pull a stick of memory out and then fire it back up it works, so i shut it back down and put the stick back in, fire it up and it works.
The same happens above if i just run one stick of memory.
So any ideas guys as i'm completely baffled.
Thanks,
Dave
Thanks,
Dave
