New PC build, would love some help
10 Sep 2019
Greetings! I'm planning on building a new pc here soon and was wondering if someone would mind checking over what i plan to buy just to make sure parts will be compatible & that i will have enough power etc etc. I will list below what i currently have in my basket, i'd greatly appreciate some advice
Thanks a lot!
Motherboard -
MSI B450 TOMAHAWK MAX (Socket AM4) DDR4 ATX Motherboard
Power Supply -
Seasonic S12II 520W '80 Plus Bronze' Power Supply
RAM -
Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black
Hard Drive -
Intel 660P 1TB M.2-2280 PCI-e 3.0 x 4 NVMe QLC 3D NAND Solid State Drive
DVD Drive -
Asus 24x DVD±RW DRW-24D5MT SATA ReWriter - Black (OEM)
Processor -
AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail
Case -
Aerocool V3X Advance Devil Red Edition Midi-Tower - Black/Red
Graphics Card - I will be using one i have already ( Radeon RX 570 8gb DDR5 )
I also plan on buying an operating system elsewhere
I have a new (ish) CPU fan i plan on transferring across also
Will i need a seperate sound card?
Do you really need an optical drive? Get a better PSU. Get a SSD. And you don't need a sound card unless you're serious about sound.
My basket at Overclockers UK:
Total: £566.05 (includes shipping: £11.10)​
I've left off the case as that's a matter of personal taste.
Hello and thanks for your reply. I have now swapped out the power supply for the Seasonic S12II 520W '80 plus bronze' and swapped the HDD for a SSD although it does increase the price quite a bit (I also have an external USB hard drive). Regarding the optical drive, yeh i would like some kind of disc reader for DVD/games (I will enquire the USB ones)
Everything else will be compatible with each other without any issues? Thanks again for replies
Do not get that PSU (the Seasonic S12II 520W), it's an ancient design and over priced for what it is.
Spend the few quid extra and get a modern unit like one of the following:
Total: £186.89 (includes shipping: £0.00)
I'd personally opt for the Bitfenix Formula.
As for the RAM, Ryzen likes faster memory, I would not recommend buying a 2400mhz set when the difference between that and a 3000/3200 is minimal. At the very least get a 3000mhz kit.​
With regards original question, no to separate sound card.
TV or monitor with speakers will be fine over hdmi cable.
Headphones or speakers no problem via appropriate lead.
The timings are better on the Team Group RAM but the higher frequency on the Vengeance makes up for that , but you pay 40 quid more. I'd pay extra for the vengeance
