New PC for rendering - 3D Studio Max etc
18 Oct 2002
At home
Hi,
G/f is looking for a new PC, mainly for using 3d studio max and photoshop. Was wondering what is most important, ram / cpu or gfx card ?
Thanks.
RAM & CPU.
Dual or quad core, and 2 or 4GB RAM.
A half-decent graphics card will also help a little for the actual design stage, as they'll use the hardware acceleration, but it won't be used at all in the actual rendering process.
What's the budget, and what is/isn't needed? (OS, optical drives etc?)
CPU, then RAM and having 2 fast hard drives. Build round a Q6600, 2-4GB of RAM, a Asus P5K and a couple of samsung spinpoint 500GB drives and you won't go wrong.
I'll take a difffent tack on this (as I use these programs quite a bit :))
Here is the main pro's to getting a better version of each and then you can judge what you need/want.
OS - 64 bit - it does make a difference (in rendering with 3ds max 2008 - 9 has some issues - on a 64bit chip) and allows more ram usage. (I'm using Vista Ultimate 64bit)
CPU - faster the better for rendering/filters etc but will not make too much of a difference in general day to day use.
RAM - the more the better (I would recommend no less than 4GB)
GPU - Well I personally use an ATI FireGL v5600 (I couldn't fit any larger in case), theres also the quadro fx from nvidia, and it makes a considerable difference in the viewports of 3ds max, general usage its the same as a 2600xt more or less. The more expensive the quadro/firegl the faster the performance, however there's no impact to render times and also relatively little gain according to benchmarks.
Some say the 8800gt etc are ok for 3ds max but in certain scenario's it will have issues - depends more on how large the models etc are and how serious a user your gf is. They have around a 1/3rd of the performance of my v5600 in benchmarks. Photoshop will be fine with just about anything :D
HD's - well I have 2 fast drives with one having a seperate page file on it.
The rest of the components are upto you really.
Thanks, just need to get an idea won't be getting a PC til probably feb time realistically.
Just saw all the other replies, thanks have copied and pasted to g/f to see what she thinks.
Here's the thing about CD rendering and CAD design. They will benefit (need) a proper GFX card that is designed for the job. Not a gaming one. They are called nVidia Quadro and Ati FireGL. Sadly I don't think OcUK sell either of these.
P.S. Pack it full of Ram.
