Hi Guys
I am looking at building a new machine, I have a rough Idea of what I want, so i will post it, and let me know if you think something should be changed and why. I intend to watercool the machine as i would like to overclock, I am however wondering about ram. I want 4GB, probably in a 2 x 2GB arrangement, but I am confused by the timings etc. Im guessing DDR 8500? Pls advise:
Spec so far:
Q6600 Quad Core G0 (is that the SLACR one?)
Asus P5Q-E Motherboard
4 Gb Ram
BFG GTX 260 GFX Card
Hiper Osiris Case (or would the Antec nine hundred be better for fitting in watercooling?
2 x 500GB Samsung Spinpoint F1's
Pioneer 215DBK
Logitech MX518 Mouse
Logitech G15 Gaming Keyboard
Corsair TX 650W ATX2.2 SLi Compliant PSU
Not sure on what watercooling setup yet (any Tips?)
Now the next question is Monitor, I am looking at the Hanns-G 28" at £270 ish, but it has a TN panel, or do i go for the cheaper OCUK 24" which has a PVA Panel? My current monitor has an IPS Panel but is only 20.1 inch
Is the G15 motherboard much better than the G11?
What speakers? and should I get a proper sound card or are the Built in sound cards okay nowadays?
Is there much merit to watercooling the Chipset aswell as the cpu, or would a chipset heatsink and fan suffice? best to leave GFX card cooling alone for now?
I want to keep my budget as close to £1000 as possible, it's going to go over, but not by much hopefully
DJH
Spec so far:
4 Gb Ram
Pioneer 215DBK
DJH
