New PC - PLEASE HELP
11 Aug 2007
Preston, Lancashire
Hi there :)
Im looking to build a new system based around a Q6600.
This is what I was thinking of using.
Motherboard
Memory getting 4gb of this
Watercooling
Case
Graphics Card
Can anyone please analyse this and suggest some changes?
Is that water cooling kit compatable with that mobo? Is there a better water cooling kit availible for me?
Can I attach both cooling kits to that case? Can you recommend an alternative case?
Is the memory ok for that mobo?
Thanks
Farore :)
weescott said:
Hello and welcome :)
I would go for a normal Ultra and get a D-tek Fusion waterblock instead.
Hi
Thanks for the kind responce! I am looking forward to being an active member in the OCUK community!
Could you please elaborate your reasons for doing the above, instead of going for the levithan graphics card which is pre water cooled?
Thanks
Farore
Edit: Would you put that water cooling block on something like this:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-032-EA&groupid=701&catid=56&subcat=877
Do you know if the watercooling kit above in the OP would work with the motherboard in the OP? Are the diameters of the pipes the same? Will it fit?
And would it be better to buy a seperate watercooling block for the graphics card or use the one provided with the Swifttech kit?
Apologies, I didn't notice you opted for the whole swiftech kit rather than just the CPU kit (which has been out of stock for a while). I think the MCW60 will need a G80 adaptor plate for the GFX.
Tubing should be fine.
I can't see any reason why the CPU block won't fit on the motherboard.
EDIT:
Custom option:
D-Tek Fuzion CPU block
D-Tek Fuzion GPU block
7/16 Masterkleer
T-line or RES
Thermochill PA120.2
DDC 18w pump
Swiftech F barbs (for easier ram watercooling routing)
2 x Yate Loon fans
Looking at about 220ish for that lot.
You can't replace the barbs on the RAM, so it's 3/8ths all round if you want that RAM. This has got the makings of big spend, bigger disappointment written all over it.
You want a system with a Q6600 in it, so current wisdom says you need a P35 motherboard. I'm going to suggest the Gigabyte P35-DS4 because it runs cool, and has every feature you could sensibly want.
For RAM, I would suggest 4GB of Crucial Ballistix PC8500. It's simple, fast and proven. 2GB is plenty at current prices though.
A good PSU is absolutely essential in this sort of system. Corsair 620W is the minimum I would suggest, better yet PC Power & Cooling 610W.
I'd also seek out the custom cooling suggested by WeeScott as it's about as good as it gets these days. While you're at it, look at buying a customised case cut to take a big (120.2 or 120.3) radiator in the roof or floor. Cases like the Akasa Eclipse 62, Lian Li V1200+II or V2000+II are excellent for this.
I'd also bodyswerve the Leadtek video card in favour of a BFG or EVGA card fitted with a proper block.
A good water-cooling specialist's advice will be invaluable in this sort of situation.
Edit: I *think* the spec on the web page is wrong. They are 1/2" barbs
The barbs are 1/4" on the ram so some sort of adapter/reducer would be required to enable it to work with the swiftech kit.
They supply 2 sizes I believe - 1/4" in the US and 3/8" in Europe. In either case, you could use an adaptor, but why compromise the whole loop to cool the RAM? And yes, I have seen those studies that show very little difference between 3/8" and 1/2", so maybe not such a big issue.
OK, so far, I have....
Graphics Card EVGA GeForce 8800 Ultra SuperClocked SILENT 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (768-P2-E887-AR) £469.99 1 £469.99 OCUK
Monitor Samsung SM-245T 24" Widescreen LCD Monitor - Black £469.99 1 £469.99 OCUK
Power Supply Enermax Galaxy 850W EGX850EWL ATX2.2 Modular PSU £158.61 1 £158.61 OCUK
Case Lian-Li PC V2100 PLUS Black Aluminium Full-Tower (No PSU) £205.61 1 £205.61 OCUK
Hard Drive Western Digital Caviar RE2 500GB 5000YS SATA-II 16MB Cache - OEM £89.29 2 £178.58 OCUK
Processor Intel Core 2 Quad Pro ***G0-stepping (SLACR) Q6600 runs with a TDP of 95W*** £176.24 1 £176.24 OCUK
RAM Crucial Ballistix 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit £140.99 2 £281.98 OCUK
Motherboard Gigabyte GA_P35_DS4 (Socket 775) PCI-Express DDR2 Motherboard £111.61 1 £111.61 OCUK
Keyboard Razer Tarantula Advanced Gaming Keyboard - Black £76.36 1 £76.36 OCUK
DVD Drive Samsung SH-S183ABEBN 18x18 DVD±RW Dual Layer Serial ATA ReWriter (Black) - OEM £21.14 2 £42.28 OCUK
Power Splitter Belkin 8-Socket SurgeMaster with Telephone & Network Protection (F9M824UK2M) £19.96 1 £19.96 OCUK
Mouse Pad Icemat - Black 2nd Edition £19.62 1 £19.62 OCUK
Mouse Logitech G5 Mouse V1.2 £0.00 1 £0.00 HAVE
Sound Card Creative X-fi £0.00 1 £0.00 HAVE
Speakers Logitech Z5500 5.1 £0.00 1 £0.00 HAVE
Cooling 1 £0.00
1 £0.00
1 £0.00
£2,210.83
Grand TOTAL £2,210.83
This is without watercooling...I need a water cooling expert to help desperately please! Any assistance will be appreciated! :confused:
WJA96, do you use MSN? Or anyone? :) I need to talk to a watercooling expert!
Sorry, no - but try my trust e-mail. I check that about every 30 minutes.
