New PC won't work, Need help please
8 Jan 2009
Hi all
So I've upgraded my PC(or basically got new one)with the following parts...
- Asus P5E Deluxe Intel X48 (Socket 775) PCI-Express DDR2 Motherboard
- Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40 GHz (1066FSB) - Retail
- Akasa AK-966 Blue Aurora (Intel LGA 775)
- Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ).
So my PC now consists of these parts plus the following
- Geil 2x1GB DDR2 Memory
- PNY GeForce 8800 GT 512Mb GDDR3
- And a power supply of 600W
When I turn My PC on nothing appears on the Monitor. And The DVD Rom Drive does not work.
The Graphics card has a slot for the PCI E Powercable so when I remove this and power on the PC again the DVD Rom Drive works and there is a long continuos beep.
Does this mean that 600W is not enough in order to run these components or is there something else wrong?
I have sticked only 1 Ram Card and also tried my Older 256 Ram Sticks.
Another time I pluged the Monitor into the port 2 of the GFX card and I also tried my Previous GFX card (BFG Gefore 7600 256MB). But still cannot enter the bios and nothing appears on the monitor.
All power connectors connected including the 4 or 8 pin for cpu power.
Try a CMOS reset.
geforce 8 cards have had some motherboard compatibility problems on earlier grpahics bioses.
How old is the card. Is it second hand?
I got this card sometime last year, around April and got it from here (overclockers).
My previous GFX card (BFG Gefore 7600) also came from overclockers in April 2007.
They were both New.
Another question, if my computer consist of these compenets...
What would the minimum amount of power supply be?
400W minimum i say at 100% load from a very good PSU, without accounting for spikes, overclocks etc. however it will be a very bad idea to get a 400W PSU to run that system on, so a minimum of 500W is what i would recommend.
