New Power Supply
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi, I am thinking of possible selling my 8800GTS and buying an HD2900XT, problem is my PSU proberbly wont handle it and wont work eaither due to the fact I have only one PCI-E connector.
I have about £50 as my budget is £400 for the new upgrade.
semi-pro waster said:
For £50 I think you are unlikely to be able to improve much on the PSU you have, if you can stretch to ~£70 then I'd go for a Corsair HX 520w. :)
Agreed, cant get a much better PSU than the Corsair. :D
Well I guess I'll have to upp my budget.
Might aswell ask in this thread and not create another thread but with the stock cooler of an E6600 and an Asus P5N-E SLi nForce 650 (Socket 775) PCI-Express DDR2 Motherboard, am I likely to be able to overclock it to a speed that does not bottleneck my 8800GTS, like 3.3Ghz?, because in my budget I was going to use the money I now need to use for a new PSU for a CPU Cooler and NB Cooler but now I think I will just use the stock cooling.
