New power supply ?
  • Thread starter Thread starter Deleted member 54091
  • Start date Start date
Hi
Can anyone recommend me a good cheap power supply.
I have a budget of around £50 max. Power usage between 500-650watts
Any recommendation would be welcomed and experiences of the following psu's
I found the following at ocuk.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-200-CM
http://www.overclockers.co.uk/showproduct.php?prodid=CA-034-CS
http://www.overclockers.co.uk/showproduct.php?prodid=CA-045-OC&groupid=701&catid=123&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-037-OC&groupid=701&catid=123&subcat=
That Antec 650w new truepower is stonking, but if out of budget, then it is.
The High current range get solid/positive reviews.
The Antec 650w is out of my budget tbh but i'm tempted to stretch for it to save me buying another one if i decide to build a new PC in 2-3yrs.
If i wasn't, i'd probably go for the OCZ ModXStream II.
I was stuck between the OCZ ModXStream II and Antec True Power 650W. I decided to go with the Antec because its: Very solid, modular, cool, quiet and the efficiency is 80%+
