Alpenföhn Matterhorn Black CPU Cooler @ £39.95 inc VAT
Due to popular demand The matterhorn Rev C returns as the White edition a completely white version based on the original and award winning matterhorn.
The Design of the heatsink maximises the amount of fins fitted in a relatively small area allowing for the heat dissipation of larger coolers on a much smaller footprint.
The 6 U shaped heat pipes optimise the transfer of heat from the CPU plate to the Fins
The Wingboost 2 fan new aerodynamically improved wing geometry we could not only increase the airflow but as well inprove the static pressure at lower noise.
WB2-Technology
Many users ask themselves…what are WingBoost´s? WingBoost´s are ridges on the
impeller that guide the air on the air-inlet side of the impeller. Using the WingBoost 2
technology air turbulences are reduced wich leads to a lower noise level at full speed.
S-Shape geometry
With the improved S-Shape geometry we could reach a higher static pressure compared
to conventional designs.
HD-bearing:
The new developed HD Bearing (Hydraulic Bearing) reduces friction noises to a minimum and thus enables to a quiet operation.
Heatsink Spec:
- Size: 138x123x158mm
- Weight: 657gr
Fan Spec:
- Size: 120x120x25mm
- Rated Voltage: 12 VDC
- Speed: 500 - 1500 RPM
- Airflow: 106 m³/h
- Bearing: HD-Bearing
- Auto Restart: Yes
Only £39.95 inc VAT.
ORDER NOW
Alpenföhn Matterhorn White CPU Cooler @ £39.95 inc VAT
ORDER NOW
WB2-Technology
S-Shape geometry
HD-bearing:
Heatsink Spec:
- Weight: 657gr
Fan Spec:
- Airflow: 106 m³/h
- Auto Restart: Yes
ORDER NOW
ORDER NOW
