Hi Guys Just set up a new case from Lian Li which actually caters for some water cooling straight out the box. Room for a 280mm Radiator in the top and removable hdd bays.
Stock should land in 2 weeks
Lian Li PC-A51WX Midi-Tower - Black/Black Window @ £124.99 inc VAT
Thermal Solution
The PC-A51 sports a reverse airflow design in which cool air is pulled into the chassis from the rear filtered 120mm fan. The front 140mm fan above the front-mounted PSU pulls hardware-damaging hot air out of the case.
New Tool-less HDD Tray System
- Hard disk installation is quick and easy.
- Supports five 3.5” or 2.5” HDDs.
- The HDD tray can be removed to make more room for high-end graphics cards.
Front-Mounted PSU
The front mounted PSU allows the PC-A51 to be shorter and smaller while still providing full hardware capabilities.
Integrated Water Cooler Support
The PC-A51 is designed to support the majority of commercially available integrated water coolers.
Technical details:-
- Dimensions: 230 x 393 x 489 mm (W x H x D)
- Material: brushed aluminum (front cover, body)
- Weight: about 4.9 kg
- Color: Black
- Form Factor: ATX, Micro-ATX, Mini-ITX
- Fan total possible:
- 1x 140 mm (front)
- 1x 120 mm (rear)
- 2x 140/2x 120 mm (cover)
- 1x 140/120 mm (bottom)
- Of this pre-installed:
- 1x 140 mm (front)
- 1x 120 mm (rear)
- Radiator Mountings:
- 1x max. 280/240 mm (lid)
- Filter: cover, front, back, ground, power supply (remove)
- Drive Bays:
- 1x 5.25 inches (external, tools)
- 5x 3.5 / 2.5 inch (internal, tools)
- * 3 x 2.5 inches (internally to the motherboard wall at remote 3.5 / 2.5 Brackets and Bracket)
- Power Supply: Standard ATX 1x (optional)
- Expansion Slots: 7
- I / O Panel:
- 4x USB 3.0 (internal connection)
- 1x per HD Audio In / Out
- Maximum graphics card length: 280 mm (without any disclaimer)
- Maximum graphics card length: 400 mm (without HDD cages)
- Maximum CPU cooler height: 175 mm
- Maximum PSU length: 160 mm
Only £124.99 inc VAT.
ORDER NOW
Thermal Solution
Front-Mounted PSU
Technical details:-
- Color: Black
- 1x 140 mm (front)
- 1x 120 mm (rear)
- 1x 140 mm (front)
- 1x 120 mm (rear)
- Drive Bays:
- I / O Panel:
ORDER NOW
