New PSU showing same problem as old
23 Feb 2011
Norf London
Hi All
I have recently upgraded my PSU from a fsp250w to a new seasonic 300w 80+.
I checked the power calculator for my specs and 300w was above the suggested wattage. I have added a newer graphics card and figured this into the power calculator. (too embarassed to say its only a fx5500, so dont tell anyone).
I did this because my 12v rail was showing 12.5v on the fsp.
My new PSU is also showing 12.5v on the 12v rail.
Is it possible that the device thats reading from my 12v rail is malfunctioning
or
That the 12.5v reading is how it has always been.
Or am I worrying about nothing.
Thanks
Most PSUs supply slightly over the rated figure. 12.5v is within the 5% tolerance given in the ATX specifications so there is nothing to worry about :)
You'll probably see it drop closer to 12V when stressing the CPU/graphics card.
What are you using to read the 12v?
If software, then it's probably picking it up wrong.
You might be better to grab a PSU tester, which is only a few £ and use that to test it, but chances are its a software / bios issue as it's highly unlikely the new PSU is at fault.
Thanks
I got the readings from my bios - pchealth page and use pcwizard. I guess pcwiz reads from bios.
It does fluctuate from 12.47v to 12.6v, but averages at 12.54v. Is this what is known as ripple?
I will test the voltage. Do I just insert the prod into the molex. If yes, which pin. I think yellow is 12v?
Thanks for the confidence in knowing it is within ATX specs.
Been worried about this ever since I started looking in my bios.
I will look at the two articles.
Thanks again
I read the articles and feel a lot more confident that my psu is fine.
I also came across the following article, which I found quite easy to understand, given the subject matter.
http://www.dansdata.com/gz028.htm
Discusses the whole PFC or no PFC issue.
I got the impression that it will not save me money in electric bills, as advertised. But will help control ripple.
I will also know which component to look at if my tv, monitor or lights start to flicker.
