Hi, I have just brought a new Radeon 7000 for dual display from overclockers but when I have the SVIDEO lead plugged into the back of the card whatever monitor is plugged into the right hand VGA socket then displays everything with a striping effect.
Its as if all the colour is being smudged in a horizontal line across the screen...bit like ghosting.
Has anyone come across this, I dont want to return the card if it can be easily fixed but by the looks of things it may be a faulty card.
When I pull the SVIDEO cable out everything works fine!
Also this error occurs all the time....during bootup also so im guessing its not software based!
THANKS!
THANKS!
