Hi,
My latest build is being a pain in the ass tbh, jumping from a problem to another, and in the latest I got kinda stuck.
My build:
i5 6600K
ASUS GTX 970 directcu II OC 4GB
Gigabyte Z170-GAMING K3
Kingston Fury Black 16GB (2x8GB) DDR4 2400MHz
SAMSUNG EVO 850 240GB
Super Flower Golden Green HX 550W
At first, it simply wouldn´t give signal to the monitor. To make things worse, after some time it simply restarted, so I could not even access to the BIOS.
Removed the graphics card from the rig and connected the computer via HDMI to the monitor. Nothing happened.
Tried changing the 2 RAM modules, and it was weird because sometimes with one module in a certain slot it worked, but other times it didn't. After some experimentation with the RAM modules I thought that it was stable, so proceeded with Windows installation, still without the graphics card.
The installation of Windows 8.1 was going fine till the point the process required the computer to restart. Basically it did not turn off completely. The monitor lost the signal, but the fans, leds and everything in the computer was still running. Left if for a few minutes and at the end turned off manually. When turning it on Windows 8.1 was installed and running, so no problem's there. Turned it off to try it with the GPU and the computer again did not turn off completely. This only happened twice, as I turned it on and off a few more times to check it, but never happened again.
With everything working fine I decided to add the GPU, but when installed the resolution went to 1024x728px and couldn't be changed. I assumed that it was because of the BIOS or tthe drivers, so I just removed it and went to update the OS to Windows 10 before updating anything.
Updated to Windows 10 without the GPU in the rig without any issues, running at 1920x1080p. Added the GPU, connected it through a HDMI and the resolution went again to 1024x728px.
It happened before with other builds, so I just assumed that it was something with the BIOS or the drivers. Updated the mobo bios via Q-Flash and nothing changed. Decided then to go to GPU drivers.
Tried first installing Nvidia Game Ready Driver software, as the Asus UK link of drivers for my GPU was not working. Updated some drivers from there but nothing helped, and, as a matter of fact, it went worse, because previously in the panel resolution I was able to choose different resolutions. It wouldn't work, saying 'The resolution you have selected can not be applied', but now I was only allowed to choose between 800x600 and 1024x728.
Went to the Asus US website and manage to download a BIOS update for the GPU, but again, nothing improved. Last think I tried was installing a different version of the Nvidia Game Ready Driver (just for the sake of trying something). During the installation it removed all the previous drivers and started installing new ones, when it said it was going to restart the pc. The monitor lost the signal, but the computer did not turn off completely. Waited for like 10min and ended up doing it manually.
The problem starts here: The monitor has not received signal again. Again, it turns on, led's and fans do start, but the monitor do not receive a thing. First I tried without modfiying anything, afterwards I tried removing the GPU and going back to the integrated graphics. Then I thought I would try to swap the RAM modules, but without luck this time.
At this point I just do not know what else I can do. Everything is connected right, but still the monitor does not get any signal.
My build:
i5 6600K
