I'm looking to upgrade the sound on my PC by adding a new sound card and was wondering if anyone had any recommendations.
The sound card will only be used for gaming, mostly FPS games, at the moment it's PUBG so footsteps and directional sound are important.
I'm currently using HD599 headphones but will consider changing these in the future if there are better ones available.
Budget for the sound card is £200 (not including the headphones).
I've been looking at the Soundblaster range but I'm unsure if the more expensive models are worth the extra money or is it just additional features that I'll never use. I'm not limiting my options to just Soundblaster though.
I've borrowed the Sennheiser GSX1000 from a friend and although the positional sound is very good, I've had a hard time hearing footsteps so the lack of settings that can be changed has put me off buying this.
Any recommendations are appreciated.
