New system build
How about this, (assuming you don't need a copy of Windows 7, monitor or peripherals).
YOUR BASKET
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £167.99
1 x Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £84.98
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) £58.99
1 x BitFenix Shinobi Gaming Windowed Case - Black £56.99
1 x OCZ ZS Series 550W '80 Plus Bronze' Power Supply £52.99
1 x Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £35.99
1 x Sony Optiarc AD-7280S 24x DVD±RW SATA ReWriter (Black) - OEM £16.98
Total : £489.91 (includes shipping : £12.50).
Can overclock if you wish to, but even at stock settings it'll be more than enough for a basic home/office machine.
Could easily go for the 430w CM psu, with the case would get £20 off with voucher CMDOUBLE.
Also OP, it's a good idea to get the 2500k as even if you don't plan on overclocking it now, if it's still running in say 3-4 years and programs require abit more processing power it'll still be an option to overclock it and squeeze the last bit of life out of it :p
For PSU, it depends on the graphics card, if any. If none, just get a reputable low power PSU, like a Corsair CX, a CM Silent Pro, Antec or XFX, or that OCZ (although I don't trust OCZ that much, but Sirtec ain't a bad OEM). 400W or there about is plenty. If you think of going with a gaming graphics card later, get a gaming PSU, 550W or over.
I would recommend the Z9+ as well, if you can spend a little more towards it. Although technically, it's a gaming case, it is packed with features (like good airflow, air filters, a fan controller for noise, cable routing for a nice clean build, and enough room for a decent graphics card).
The rest, don't need to change :)
The 2500K allows for overclocking, plus it will retain its value better.
If it's for office use, then a i3-2120 or there about will do the job nicely.
The Z68 motherboard gives you more options in the future (IvyBridge, overclocking, ect...).
I just use it for general office use - browsing, email, documents, photoshop, HTML editing, that kind of thing. Nothing too heavy.
At the moment I plug one monitor in using normal VGA and the other using the white digital cable
Stick with that ASUS board then, as it has more outputs than the Gigabyte, which you'll need for your two monitors.
As for hdd, I will be replacing my 4 year old dell dimension with this one so could always use the hdd from that. I think it's about 250gb 7200 rpm sata
You will sacrifice specs for an SSD, so at this stage I'd probably stay stick with that spec and get one later if you want to.
Sound like I'm almost there with regards to spec. Next is to decide on aesthetics - fans, cables, colour scheme, etc - the fun bit
I'm thinking of a couple of additions for this build:
1) solid state drive to hold the os and programs - not sure which one though
2) I will probably end up installing braided cables at some point so wonder if a modular psu would be better? I could just use the braided cables as extensions but would this affect performance?
YOUR BASKET
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £169.99
1 x Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) £107.99
1 x Asus P8Z68-V LX Intel Z68 (Socket 1155) DDR3 Motherboard £89.98
1 x Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT064M4SSD2) £77.99
1 x Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply £64.98
1 x Zalman Z9 Plus Tower Case with Fan Controller - Black £49.98
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £38.39
1 x Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) £25.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £14.99
Total : £655.27 (includes shipping : £12.50).
PSU is overkill really but modular and all the power you will ever need. Lil SSD to boost the OS and software plus a fast 2TB storage drive.
I use that Z9 case a lot. 4 fans supplied (3 lit blue), with digital temp display and a fan controller with cable management as well. It's excellent value for money :)
Not THE cheapest Z68 mobo but has more video outputs than the cheap GB mobo. You could add a budget gaming card later if you wanted. Not just for games but it frees up the i5K internal GPU to be used to help with encoding videos (quick sync).
You might have noticed but the weekly and daily offers can make a big difference to what we spec. So double double check your spec right before you buy bud.
Good luck with the build any problems or questions......that's why we are here ;)
Thanks for that.
You suggest a 64gb ssd, would that be enough for win 7 and the programs?
I don't think I will need the hdd as I will take the one from my old pc. It will only be used for storing files so doesn't need to be particularly high spec. I keep most of my files on an external hdd so I can work from laptop or pc (although I'm not sure this is the best method to do this).
I like the p8z68 LX mobo as it has on board graphics. However, I have two monitors to plug in. I'm wondering if it might be better to get a graphics card for that. I don't do any gaming though so don't need anything big. If I get a graphics card I can look at other mobo's as I wouldn't need the onboard graphics on the p8z68.
Are there any other advantages to having a modular psu other than cable management?
I am quite liking the bitfenix case mentioned above but this does look good too. I would replace the led fans though as I'm not keen on led fans.
Hmmm, food for thought
64GB will be enough for Windows and a few programs, any which don't fit can be installed on an HDD.
It is the CPU which has onboard graphics, so any of the Z68 boards will work. However the cheaper Gigabyte only has an HDMI port. The Asus has 3 ports, and you can run 2 monitors off it so that isn't a problem, you only need a graphics card for gaming really.
Other than cable management, no other difference.
Ah, that explains why I can't find any specs on the graphics for the mobo then. Thanks for clearing that one up. I usually just plug one monitor in the dvi and one in the VGA.
Would you say the gigabyte board is any better than the asus? I can always get that and a cheap graphics card?
Might go With the corsair 430w psu to save a bit as both cases look good for cable management
Thanks for that.
My mate Beej has covered most of your questions well fella.
I use that Z9 myself. I moved the side panel fan to the top of the case and the rear exhaust to the bottom as an intake. So i have 2 120mm sucking in cool air and the two blue 120mm fans at the top (hot air rises remember) blowing out. Both are on the fan controller, when set to low it dims the lighting along with the fan speed/noise.
I have a 630W modular PSU. I do recommend them, as you dont seem to want to fit a dedicated GPU you wont need the power cables for it......so you don't plug them into the modular PSU, less clutter in the case = better airflow. The cooler the kit in the case is the longer it's life expectancy is :)
