MMMMMMMmmmm thats putting a dif spin on things!!!!!!!!
I thought the 2600 was as quick but once you got the old 990 cranked up it would pull away.
As they say! CRAP what do i do knowneed a new list lol
tbh you sound like you need some sr-2 dual xeons 590 quad fire to keep you happy.![]()
I have a £30 case with holes cut and no sides on it
The case will not halp with FPS
what would you rather your PC looked like
this: http://www.overclockers.co.uk/showproduct.php?prodid=CA-203-CM&groupid=701&catid=7&subcat=29
or this: http://www.overclockers.co.uk/showproduct.php?prodid=CA-203-CM&groupid=701&catid=7&subcat=29
Its an old large server case i found. Cant get a nice fancy one due to having Phase change so need the holes. As for temps i get -53 idle but with the new unit i will get -30 @310watts poss -40c
No its at the side as its to big. Its using a Rotary Motor.(taller)
