New system imminent need eyefinity setup
26 Dec 2008
Edinburgh
Been humming and hawwing between an eyefinity setup, dual 24"s or a single 27" screen. My new PC rig that I have purchased is going to be serious overkill so I am looking to get a monitor setup to suit this!
I'm looking to find 3x22" monitors to be used in the eyefinity setup which I'm planning.
Whats my best options? I may be tempted by 3x24" monitors but don't want to spend too much more than £500-600 for the monitors.
Any help greatly appreciated.
I'll be running a watercooled 7970 OC'd GPU to power them.
In the same boat be interesting to hear people's opinions.
My options similar to yours;
Infinity setup - but the bezel issue might annoy me massively
A 120hz screen, a benq or a samsung and save the rest of the money
A 27 or 30 dell or hazro
Seriously this is the hardest thing to decide on!! I've already sent a 27 inch 1080p panel back because 1080p at 27 inch sucks!!
I've noticed a load of monitors don't have a display port on the 22"s. Am I able to use a DP > DVI converter and eyefinity will still work?
You need an active adaptor but yes.
Personally I'd either go 120hz 24" or >1440p 27"
Eyefinity is overrated in my opinion, too much screen distracts you in fps. That said it's much better for sims etx.
i can say that 25" 16:9 1080p is good enough to be a monitor (just tbh) but above this pixel pitch is poor. If only there was a 21:9 30" monitor at beyond 1080p :( then you could have your cake and eat it.
i wouldn't go smaller than 24" for eyefinity personally. I had 3 x 2048p 23" samsungs they were crisp but the lack of verticle height grated a bit too much.
i can say that 25" 16:9 1080p is good enough to be a monitor (just tbh) but above this pixel pitch is poor. But i can also say 23" isnt large enough and with landscape eyefintiy it just feels weird as you crave for more vertical height. If only there was a 21:9 30" monitor at beyond 1080p :( then you could have your cake and eat it.
i wouldn't go smaller than 24" for eyefinity.
Which 24" then? I'm thinking either the U2412M or the XL2420T.
