Hi Guys,
Fancy a new PC and been looking at a few bits in the store. How's this system look? To be honest, I'll just use it for browsing, email and a bit or word. Also Have a lot of MP3s so went for a decent soundcard. Am I on the right track, all of the bits look OK and will the work together? Know nothing about PSUs so could do with a recommendation?
AMD Athlon 64 X2 Dual Core 6000 3.10GHz (Socket AM2) - Retail £59.99
Asus Xonar DX 7.1 PCI-Express Sound Card (Low Profile Compatible) - £49.99
Abit AX-78 AMD 770 (Socket AM2) PCI-Express DDR2 Motherboard £45.99
PNY GeForce 8800 GT 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - £44.99
Maxtor Diamondmax 22 500GB SATA-II 32MB Cache - OEM (STM3500320AS) £36.99
OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK) £31.99
Arctic Cooling Freezer XTREME CPU Cooler (Socket LGA775/AM2+/AM2/939) £31.99
Arctic Silver 5 Thermal Compound (3.5g) £4.99
Total £360.63
Thanks,
Martin
Total £360.63
Thanks,
Martin
Also do you really need an expensive CPU cooler?
