Hey all, just built the system up yesterday, got it all sorted now (keeping xp instead of vista for now)
E6300 @ Stock w/ AC7 using thermal pad that came with the AC7 set via bios to Qfan control (Not getting extra setup options in bios like i was told i should do
Asus P5N-E SLi
2GB OCZ PC6400 Ultra Low LAtency RAM
EVGA 8800 320MB Superclocked
Just wanted to check all is looking ok really
I was thinking MB temp might be a tad high?
Also GPU is sitting at about 62C idle?
)Asus P5N-E SLi
I was thinking MB temp might be a tad high?Also GPU is sitting at about 62C idle?
