- 13 Jan 2004
- Leicestershire
Hi all,
system is:-
intel 2500k
64GB Crucial M4 SSD S-ATA3 Solid State
Gigabyte Z68AP-D3
G skill 2133mhz DDR3
Got it to light up motherboard, spin CPU fan, spin blu ray drive, heard SSD drive going bu no video at all.
Why?
Using exactly the same card in my AMD setup now.
Card is a 4350 radeon according to CPU-Z and doesn't require extra power.
Tried plugging in a 500w and a 600w psu from amd - using 24 pin and 4 pin so should have booted up hard drive from amd setup shouldn't it?
either way - wouldn't boot to bios or nothing - monitor just said connect video cable.
as said - cable and 4350 are ok as using them now.
looking like motherboard? it lights up and the lights go out to mean i guess they've passed inspection?
Intel are crap.
system is:-
intel 2500k
Gigabyte Z68AP-D3
Why?
Intel are crap.
The 2500K has a built in GPU, it's not very beefy, but for anything but games it's spanky. As Stulid has said if you can plug in your monitor direct to your motherboard, that will eliminate one possibility and you can narrow down the problem. Even if you pull the HDMI lead out the back of your bluray player or Sky box just to test things it's worth a shot.
