- 10 Mar 2010
Right i have been thinking about replacing my Laptop (Sager NP9262) with a Desktop and i know that building it yourself can save you money. However i have NEVER built a desktop before, i have added / removed parts like RAM, hard drive, PCi slot audio items and with info i would be confident in installing CPU knowing what they are and where they go
So what do i need?
i know i need the following :
CPU
RAM
Hard drive
GPU
PSU
Case
Motherboard
DVD Drive
OS
is there anything i am missing? where would the best place to get these parts from? i know Hard drives and RAM can be easily purchased from Ebay and have done before but what about GPU and PSU?.
As i havent built a system before would it be better to just buy a basic system and upgrade as i go that way it will have all the required parts to work and i can then work at getting it upgraded with parts.
I dont have a desktop at the moment so i would be buying all the parts, i do have a Q6600 that is currently in my Laptop (Sager NP9262) which i could take out and put in the desktop to save a bit of money and upgrade later.
Some of the parts i know about, like OS, RAM and Hard drive and CPU but the most confusing would be the Motherboard, would it be possible to get a Motherboard that would work with the Q6600 but be able to upgrade to i5 / i7 in the future without having to upgrade the Motherboard.
As for Graphics i would want something like the 260 GTX and have the option for future to upgrade to SLI.
So my main question : Would it be best to build the desktop my self or buy a decent desktop and upgrade as i go rather then buying all parts and putting it together my self as i havent built a desktop my self before
So what do i need?
CPU
RAM
Hard drive
GPU
PSU
Case
Motherboard
DVD Drive
OS
