I did use my arctic TIM cleaner on the cards sli cojnector area, maybe that did ig in the end lol. its not exactly as high-pressure connection wise compared to the PCIE slt so maybe if its a bit dirty there is poor contact...
very annoying problem though and yeh one possible fix i came across was to update BIOS and format
You mean the citrus stuff made from oil?
Oh dear lol.
You need to use something alcohol based so it dries with no residue.
If you mean your motherboard's bios? I thought that had already been suggested. Old bioses hate 4 series cards. I know because my 790i was bsodding until I updated the bios when I put my 470 in there.
