NEW & UPDATED CASE MODDING RANGE ARRIVING TOMORROW
oh cheers I didn't see them there
are these dense weaves?
Sorry I m very close to getting a heat gun and braiding my tagen as I got wayyy too many wires off it, So I m looking for braiding but I cba to order form else ware
Why does the 6 to 8 pin have a massive cable for the +2 pins? Surely if you use it to convert to 8pin it'll make a massive 30cm loop poking out of your graphics and look an utter mess? :confused:
What does that massive loop achieve compared to something like:
snip
That is a very good point... I couldn't quite get what the previous poster was on about but you've hit it...
Hi,
The weave on them is fairly thick yes. Its of good quality from the ones i've seen.
Only way to find out if its 100% right for you is to buy one ;)
Phil
Any comments on the cable I mentioned? Is it actually like that or did someone just get confused in photoshop making up a product image? :p
I will be giving braiding a go.
I will try these onces of course, not sure what sizes I will need, but hay I believe 10mm= SATA, defo don't need 18mm ;p
