I am a long time lurker new time poster on these forums and I have recently realized my current pc has sat next to me for over 4 years....for at least 6hours a day.
I do not look on the face of my wife or children as much as I do my PC and therefore my next build will be as beautiful as I can make it...I will not settle for average even though I realize I will have to learn a lot of new skills. I also do not have any monetry constraints or need to worry about price to performance any more.
Over the past 15 years I have built 5-6 pcs so I know the basics and i have a few spare cases/psus and terrible fans in the garage, I even have some much fought over DDR2 sticks for prizes in the Looserdome.
I am looking to build a new system in a Lian Li O11mini with a distro plate and hard tubing. Yes I know this is not original, I am not going for unique, but I am very confused on some matters so I will list a lot of questions below.
Few early questions answered. I have run my current system at stock clocks for years. I am not concerned with extra performance but I do like silence and longevity. I am also thinking ahead to the AM5? X670? and RTX480 series so no need to be obsessed with current issues but I assume the current ATX for factor will be in use.
1- I have watched a lot of vids where they do a normal side mounted vid card in this case. If I wanted to go vert mounted then how does that limit me for the mini? It is really confusing what you can do with ATX mini atx , micro mobos in this small case. Is it just a matter of get the parts and make them fit ?
2- Considering I would be willing to run a theroetical next gen AMD Intel 8/16/32 core cpu at stock values for many years would it really matter if I went ATX, Mini ATX , Micro ATX ? Obviously I would be watercooling and if I was limited to a slim 360 rad what would my max TDP be for silent running? GPU would ofc be included into the TDP
3- Practical issues. What tools, or extra tools, do i really need for a hardlined WC build?
4- For my first WC build should I be looking to go so small or should I go for the standard O11 Dynamic?
5- Double distro plate - Side and front. Is there room in the mini ? how would it limit radiator support if at all ? Is it much easier in the normal dynamic or is that still impossible.
6- Monoblock, Asus Formula style with prebuilt vrm cooling, Standard cpu block +loop. I am not going to go for extreme performance so I do not necessailty need to do anything. Would my choices then be purely ascetic? or is there a neccesity I do not know?
7- This is the most important question. What do I not know?
Many thanks in advance and after I have sobered up I will spell check.
