- 30 May 2009
- Maidenhead
Hi guys (and girls),
So I am finally returning to custom watercooling. A few years ago I built my first loop on my i7 920. Now I have a 6850k with an AIO cooler on it. However, as I have just purchased a GTX 1080 Ti, I want to put that under water, and the CPU.
I was looking for some advice regarding fans and pumps. I want to use an Aquaero to control fan speeds on the radiators etc.
What fans can people recommend? I want to push the overclocking on my CPU and GPU, but I also want to keep noise down as much as possible. Obviously, PWM fans as I want to use the Aquaero.
And pump: I have read that EK D5 G2 pump is able to be PWM controller by the Aquaero. Can anyone confirm this? If not, I will grab an EK D5 top, and the Aquacomputer D5.
As it's been a while since I last built a waterloop, anything else I should watch out for? Tubing is another concern of mine, what are the benefits/downsides of going with narrower walled tubing? Like 10/16mm vs 10/13mm?
As for radiator etc, I looked at the EK configurator, and it suggested that a single 480 quad rad (120mm fans) would be fine to cool the Ti and my CPU. I would be going for an EK XE radiator (their top one I think).
Hopefully someone can give advice.
